Lincoln Precision tig 225 power cable
发表于 2021-9-1 00:29:21 | 显示全部楼层 |阅读模式
All,I'm new to welding and have purchased a used PT 225.  The torch power cable leaks pretty badly.  I'm having a hard time figuring out what is the best replacement.  Can anyone make a suggestion?  The torch is a Radnor 17.thanks.
Reply:Since nobody else has replied, I would suggest that you visit your local welding supply store, take your old torch, and ask them what your options are, and what they would cost.   You don't have to make a decision at that moment, but maybe it will be obvious from a cost standpoint, or maybe they will have a strong recommendation.Looking at the web, I would guess that a new torch with hose would be less than $100, so not a huge investment.The 17 model is a common one, I believe, rated 150 amps continuous with air cooling.  That should be enough for most uses.   To go much higher, you would probably need a water cooled torch, which would be a big investment, as you would need a water cooler.  I would suggest going for a direct replacement of what you have. You might consider how long a torch cable you need.   Unless your welder is some distance from your bench, you can probably live with the basic 12 foot cable. My welder is on wheels, so I just move the welder if the torch does not reach.  If you plan to TIG weld on vehicles, you might want the 25 foot cable.Maybe you don't need a new torch, just a new hose.  That is where I would go with the welding store recommendation, as they can assess your old torch, and what would be involved changing the cable/hose.If you are new to welding, the least expensive decent equipment is probably the right choice.  Don't buy junk, but you don't need a Cadillac either.I hope that someone will give you more specific pointers.I am fortunate to have two good local welding shops, so I would go in and just ask them what my options are.  Sometimes I do find a significant price difference, but usually the prices are pretty comparable.  I feel better getting two opinions before spending any significant money.Good luck and have fun,RichardSculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
GMT+8, 2025-12-22 01:32 , Processed in 0.090754 second(s), 18 queries .
