Another Cracked bucket
发表于 2021-9-1 00:29:16 | 显示全部楼层 |阅读模式
This bucket had been repaired before.  The previous repair had added a plate, but never opened up the original crack and welded it. Now the plates are cracking.Last edited by David R; 09-02-2007 at 08:26 AM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:See my welding bucket?  Rod in center, butts in outside.  I always keep a chipping hammer, hammer chisel combanatioin square and a wire brush in there. Attached ImagesReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Note there are 2 layers of plate.  Some I had to scarf both sides out, some I only went to the outside plate.Attachment 12336Last edited by David R; 09-02-2007 at 08:28 AM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:because of access with the rod, I had to weld this one all from the other side.  You are looking at the back of the bead.Last pic is cap pass.  Kinda big, but.......Rod 3/32 7018, 85 amps.   All vertical up as usual.David  Last edited by David R; 09-02-2007 at 08:29 AM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Nice work dave.What model backhoe?looks like case 580.
Reply:It is a 580.  The bucket on the back is cracked too.David  Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Dave heres a recent photo my friend took of me fluxcore welding, with his fancy camera i,m impressed with the clarity i thought you may also like it. Attached Images
Reply:nice repairChuckASME Pressure Vessel welder
Reply:nice work dave  I love the bucket thing didn't notice it at zaps place I'll have to try that
Reply:Dave, just a little friendly advice, but in my experience when one breaks thru both plates like that when I just gouged it out and welded it back it broke again.    I now take the old plate off weld the original piece and then put a new plate back on, and have yet to have a problem.  It could have been the situations I was dealing with, but just wanted to throw it out there.  Nice welding by the way. ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Jackson,  Thank youI thought about moving the plate.  This is a light duty machine to say the least.  I doubt it will see 100 hours a year.It will probably see more snow than anything else.David  Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Looks good, David. I used to do stuff like that before I got out of it....I need to get more of it again. Around here, the septic guys beat on rock all day long. They break a lot of stuff.
Reply:Hey David, looks like the bracket on each side of the bucket cracked in the same spot??
Reply:Looks good, how long did it take?
Reply:What a cheapo repair in the first place... Nice save David.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks like the crack is spreading down.  Did you address that?
Reply:Originally Posted by David Rbecause of access with the rod, I had to weld this one all from the other side.  You are looking at the back of the bead.
Reply:Nice job,Dave. I wonder if the cause of the crack is the back of the bucket is hitting something on the lift arms as evidenced by the "mushroom" next to the tilt link pin on the left side? Constant hammering like that will cause a lot of stress.                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:nice. what sorta welder have you got? my handpeice looks exactly the samehttp://datingsidorsingel.com/
Reply:Nice welding bucket, I have one just like it, but I put beer in the middle, and caps between the bottles. Really is a smart idea though, I set the ground on fire with a stub once, metal bucket should prevent that.
Reply:Originally Posted by maxyedorNice welding bucket, I have one just like it, but I put beer in the middle, and caps between the bottles.
Reply:good work dave i still like the beer idea for the bucket lol63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
GMT+8, 2025-12-22 01:33 , Processed in 0.089971 second(s), 18 queries .
