If you see this on a trail near you. . . . .
发表于 2021-9-1 00:29:12 | 显示全部楼层 |阅读模式
RUN!!!I find it hard to believe that someone would think welds like this on a safety cage are a good idea.Building a Jeep from the ground up as a graduation present for my kid. Build thread can be read at http://www.jeepforum.com/forum/showthread.php?t=259306Mike
Reply:re-post John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Yeah..If I see an X in a box?I'm runnin!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterYeah..If I see an X in a box?I'm runnin!!...zap!
Reply:...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Damn X's
Reply:I'd definately run for cover! A big red X on the ground is a sure sign of a big red ACME bomb in the sky. Double scary if there is a pile of birdseed on it.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:That is scary, it looks like some sort of dimensional portal from the twilight zone......I'd be runnin tooDon't talk about it, Just do it!
Reply:It's a picture of the goopy conduit pipe roll bar ....again. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by Joe HI'd definately run for cover! A big red X on the ground is a sure sign of a big red ACME bomb in the sky. Double scary if there is a pile of birdseed on it.
Reply:Originally Posted by FordBuilderFLBeep Beep! lol
Reply:Originally Posted by TSOR
Reply:Here's the picture. Why would I need to run from that rig?  I could stand in front of it while it was barreling at me and it would fall apart. Attached Images
Reply:Well you know, often the weld can actually be stronger than the base material. So why not construct the entire roll-cage from weld? LOLMiller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
GMT+8, 2025-12-22 01:35 , Processed in 0.086169 second(s), 18 queries .
