What would you guys charge for this?
发表于 2021-9-1 00:29:10 | 显示全部楼层 |阅读模式
At this point it might be cheaper to get someone else do it and ship it.I need the Following-20 guage steel1x 18" circle 1x 18" circl with a 2" circle cut in the middle like a donut 1x 16"x 56.5"  with a  1.5" hole 3" from the bottom Then Rolled to an 18" diameter * i am going to weld this t the outside of one of the rings.1x 3"x 56.5" I am making a Forge if you are interested. I really wish i had sheet metal equipment...
Reply:It would be a little more helpful if you post your location, might be one of us is right around the corner from you.I am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:Atlanta Georgia
GMT+8, 2025-12-22 03:10 , Processed in 0.116448 second(s), 18 queries .
