welding line pipe
发表于 2021-9-1 00:29:10 | 显示全部楼层 |阅读模式
HelloI am looking for information.Remove the  welding line inside a pipe Thank you
Reply:Could you be a little more vague please!!G
Reply:Grind it out with a die grinder, id say u are talking about the seam. Or u can drill it out if u have a correct size drill
Reply:Dynafile
Reply:probably talking about the flashing.depending on how long the pipe is.  if its short, just check a 1/2" rod or smaller that's the appropriate length, wrap some sand paper on it, then go to town.
GMT+8, 2025-12-22 01:35 , Processed in 0.089229 second(s), 18 queries .
