truck bumper fenders
发表于 2021-9-1 00:29:08 | 显示全部楼层 |阅读模式
I built a trailer and have used the small 4 lug rims (570x8). I have an old GMC chrome front bumper off my dads 72 Jimmy that is wide enough but  slightly bent in the center  from a  misguided deer. I would like to make a set of fenders for the trailer out of it. Is there anyway to bend this , or will the chrome crack at the bend? I guess heat will turn the chrome blue, as in motorcycle pipes. No radical curve, just enough to look like a fender and not a missplaced  part of a  bumper... Any Ideas? Attached Images
Reply:If you want to prove that it can be done, then yes, the chrome will prolly crack.Fenders for that size wheel are cheap over the counter.Trailer FendersCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I dont know why you would bother, TSC has trailer fenders for next to nothing.  I bet you can get a set for that for under $40.Have we all gone mad?
Reply:Yes I can buy a set of Chinese fenders  on the cheap.  Would rather build my own. Pretty much anything posted on this site can be bought if your too lazy to build it. Building your own ,not only gives you a sense of accomplishment, but IN most cases is better then anything you can buy at any store , and its something you can be proud of.  The trailer has 8 ply tires, Henshen 2500 LB rated  U.S. made  axle , Fafnir bearings. And 4 days of sweat building it from 2  junk  1949 U.S. made  camper frame  parts. My question was , how can I do it , thats all. I can lay the heat to them and shape them any way I want, what I cant do with a hammer I can do with a 50 ton press. I will refrase my question, Can you gently bend chrome plated steel with out damaging the finish? If so how? Thanks for taking the time to respond, but not the answer I was looking for.
Reply:i would cover it in leather before hammering or pressing itDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Originally Posted by wrenchit Can you gently bend chrome plated steel with out damaging the finish?
Reply:Maybe it's the angle of the photo, but I don't see any springs!
Reply:Originally Posted by TSORMaybe it's the angle of the photo, but I don't see any springs!
Reply:Originally Posted by ZTFabProbably a torsion axle.
Reply:Don't have any experience with one but if you have access to and english wheel it might do the job or it might destroy the chrome. I think it would be worth experimenting with , no heat involved and no hammering. good luck. let us know."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by wrenchit Thanks for taking the time to respond, but not the answer I was looking for.
Reply:.......Last edited by tanglediver; 08-12-2010 at 01:39 AM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-22 01:35 , Processed in 0.067960 second(s), 18 queries .
