[IMG][/IMG]this is a lincoln 275 with advance control panal,,,,,,,,pulse also i have read about the advance control panel and have been using a cheat sheet to get me by..........can someone please give me some pointer on these controls,,,,,and kinda break it down where i can understand it,,,,,,i mostly weld aluminum w/100% argon if that can be helpful any imput will help i'm sure,,,,,,,,,,
Reply:You need to resize your photos to 800x600 max before posting. When they're too large as is the one above, it cuts off the photo and text.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:From Left to RightThe first toggle switch is the trigger switch ( 2 step / 4 step)The second toggle switch is the Pulse / Spot Time Mode SwitchThe first knob is the Frequency controlThe second knob is the Pulse % on time controlThe third knob is the Pulse Background Current ControlThe fourth knob is the Downslope Time, in secondsThe fifth knob is the Spot TimeYou should have got a owners manual with your welder and you can easily pick up a catalog for your Lincoln Welder at any weld shop that sells new welders.It should be on page 11 of the new 2010 Product Catalog |
