Todays Welding Fun!..
发表于 2021-9-1 00:28:57 | 显示全部楼层 |阅读模式
I love an easy day... Couple of weldments to tackle this A.M.4 brackets to weld up..Here are the contestants..4.125" spacers with the hole locator pin all clamped down nicely..Start by tacking the ends..Now tack the inside in 2 places about 1/2" in from the ends..Heres the outside edge..I'll get to the inside next post..(No starting and stopping on corners!!)Next post.....zap!Last edited by zapster; 09-10-2007 at 04:35 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:About the inside..Notice the Tie-off..It is at the start tack..And if you do it right the pieces still stay square with the bottom plate!After those..Just a new threaded insert into a flange for a wastewater treatment plant..And YES! It smelled like wastewater.. I get all the fun jobs.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:a little undercutting on the ends or it could just be the light.Looks great as usual.  I'damiggedit.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:and notice the proper use of an american dime
Reply:looks good Zap sorry about the smell lol63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Hey zap I see you say no stopping or starting on the ends does this weaken the brackets ?Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Originally Posted by e_racer1999and notice the proper use of an american dime
Reply:Originally Posted by SteelwillHey zap I see you say no stopping or starting on the ends does this weaken the brackets ?
Reply:You will of course wash that hot, smelly dime when you're finished...I hope. Try acetone!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by WelderBoyNo, it's THE dime.
Reply:awesome welds! wish i could weld like that.
Reply:Originally Posted by WelderBoyBig time.  The most crack prone part of a weld is the end.  The least penetration part of a weld is the beginning.  Two very weak parts.  I wrap everything all the way around in one pass, it's the best way!
GMT+8, 2025-12-22 01:33 , Processed in 0.089818 second(s), 18 queries .
