Need Some Advice
发表于 2021-9-1 00:28:50 | 显示全部楼层 |阅读模式
I recently got my hands on two lengths of schedule 40 6" pipe; I am planning on making pipe coupons out of them to get back on top of my pipe welding.I'm going to cut them into 3" to 4" segments which will leave me with about 150 edges to be bevelled.My question is is it worth while going to a machine shop to get them bevelled or is that out of the question cost wise? I have not had a chance to call any local shop's due to my current working hour's would appreciate any advice.Cheer's SteveCigweld Transmig 265seBoc 140amp StickBoss 200amp AC/DC TIGLincoln Electric Invertec V260-S
Reply:Anyone?Cigweld Transmig 265seBoc 140amp StickBoss 200amp AC/DC TIGLincoln Electric Invertec V260-S
Reply:Sounds expensive.I'm going to guess they'd quote 2-3 hoursto face and bevel them.It all depends how much the shop charges and how much you're willing to spend.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:If you are going to use a machine shop. The best deal would be to find a larger CNC shop, give them the full lengths. They can load the full length and progam the machine to cut what ever lengths and bevel the ends as one process. I can't remember the exact coupon lengths required but I'm sure they are greater than 3 or 4 inches.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Cut em' with a torch and finish with a grinder. Thats what you get in the field.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:uhh also here there are some very friendly votech teachers that have students that need to learn to use beveling machines? might be a option. there usually pretty kewl bout stuff like that. slower sometimes but good for u and the kids.
Reply:My vote is to bevel them your self. Some will be great, some not so great. You will need to learn how to deal with both. Also, they should be 6 to 10 inches, it will make them easier to cut apart and re-use.Good luckUA Local 598
GMT+8, 2025-12-22 03:09 , Processed in 0.097834 second(s), 18 queries .
