A couple of Vanilla Stick welds
发表于 2021-9-1 00:28:37 | 显示全部楼层 |阅读模式
Heres a couple of welds on a vice receiver I'm putting on my table.  These were done flat, my vertical weld pictures I took are way out of focus.  I'll have to re shoot.  Anyway, the bracket is 1/4 , not sure what the receiver channel is maybe 3/16.  I used AC (no choice) 1/8 6011 at 100 amps.  As you can see I must have sneezed or something on the longer weld.  Still trying to get steadier.
Reply:The fillet weld looks like it needs more current to smooth it out.Don't know if you've tried other rods, but 6013 is easier to run a smooth bead, and 7014 spreads like melted butter on a flat fillet weld like that.
GMT+8, 2025-12-22 03:09 , Processed in 0.069328 second(s), 18 queries .
