So Who Knows What This Is? (not a welding tool)
发表于 2021-9-1 00:28:36 | 显示全部楼层 |阅读模式
I know what it is. I had to have it when I saw it. Who else knows what this contraption is. And yes it is a Dog in one pic. http://s94.photobucket.com/albums/l1...t=Vegas019.jpghttp://s94.photobucket.com/albums/l1...t=Vegas020.jpghttp://s94.photobucket.com/albums/l1...t=Vegas021.jpgDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:It's for pulling off your boots.  Put the heel in the "V" and the other foot holds it down while you pull your foot out of the boot.
Reply:DING, DING, DING. We have a winner, it is a boot getteroffer.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:It's called a boot jack.  I've seen some interesting variations, such as a large cast scorpion, or some such bug, with horns that you hook the heel in.Gary
Reply:I could've used that today after digging some draintiles and having 30 lb danner boots. Its also handy for taking off your scent free rubber boots or the yellow ones if you use those.500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:Oh man I misted this one... and I would have gotten the answer correct Me!
Reply:Originally Posted by TozziWelding getteroffer.
Reply:You can weld one of those up real quick by using 4 old horse shoes.
Reply:Its a special jig to hold your boot while you tack weld the shoes laces so they dont loosen for the 20th !#$%ing time355# Hay Budden3# Hofi HammerPropane ForgeIdealarc TIG 300/300AllStates Oxy Propane torchSmith Little Torch
Reply:In the last picture we can all see that it can also be used to beat helpless dogs into submission.  Or, maybe it's a tool for finding dogs that have been misplaced.  It pointed that one out real good Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by tresiYou can weld one of those up real quick by using 4 old horse shoes.
GMT+8, 2025-12-22 03:09 , Processed in 0.099473 second(s), 18 queries .
