got this from a scrap mill at work now i need to figure out how to get it outof my truck and in to my shed in the back yard http://i183.photobucket.com/albums/x...ldingtable.jpghttp://i183.photobucket.com/albums/x...dingtable2.jpgChuckASME Pressure Vessel welder
Reply:Maybe rent one of these (link)!How did you get it in? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:forkliftChuckASME Pressure Vessel welder
Reply:come a long, or chain and tree, or back up fast, hit the brakes with the tailgate OFF. Prolly in the grass.That looks like a table off a big milling machine or grinder. NICEReal world weldin. When I grow up I want to be a tig weldor.
Reply:yeah then its on the gound and not in the shed ChuckASME Pressure Vessel welder
Reply:That has to weigh in at 800 lbs and then some...Wholly Canollie!!Like the dime...No engine hoist laying around or that you could borrow for a while???Winter is coming..Better think of something or you'll have a nice bed weight for traction.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:couldn't you get it on a 2 wheel dolly? Or just a ramp out of 2X6s, some bars and two big fella's. I doubt you can break it. DavidReal world weldin. When I grow up I want to be a tig weldor.
Reply:I had a mate who had to move a huge piece of granite once - up some stairs. Probably weighed less than your steel, but much bigger and more awkward. He looked at hiring all sorts of lifting devices. I told him to call a piano moving company. Three islanders showed up and moved in less time and for less cost than any other option he had looked at.
Reply:Roll it on pipes?What are the aprox dimensions? Let's figure out the weight.
Reply:Call your local tow truck. His rig will easily handle that wt. You may have to set up some rigging. Cost you $25 or thereabouts355# Hay Budden3# Hofi HammerPropane ForgeIdealarc TIG 300/300AllStates Oxy Propane torchSmith Little Torch
Reply:Originally Posted by maddogCall your local tow truck...
Reply:I always use my cherry picker to unload big stuff. If you can't get ahold of it just weld some hooks on it, knock them off once you have it where it's gonna live.Anything worth doing is worth doing RIGHT
Reply:What is the big deal it's just a dime!I would look for a cherry picker.
Reply:Fabircate your table base. Attach a winch to the far end ot the table Pull it onto our table base and wheel it to where you want to go. Oh yeah, put wheels on your base. You can put your base on a trailer in ground is not smooth.
Reply:Originally Posted by denrepRoll it on pipes?
Reply:Got helium??
Reply:pipes and levers i have moved many big things this way just make sure your pipes are strong enough the hard parts gonna be getting it up on the frame350P 30A spool gun cut master 51 syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Twice I've built props to the shop ceiling joists just wider than the pickup bed then used a 4x4 over the joists and a coffin hoist to pick the heavy stuff out. The last time was a mill-drill at 760 something lbs. I only used 2x4's on that one and they got pretty jello-ee in the middle.
Reply:If you can get a tow truck to do it for $25, I think I would consider that route. Of course you still have to have some place to put it.I got a 1 ton dc winch from harbor freight for $45. That should drag it off you bed onto a table top. |
