Something New To Look At But Nothing New To Me..
发表于 2021-9-1 00:28:33 | 显示全部楼层 |阅读模式
Just a couple of rollers I fabbed up yesterday and welded this A.M. ...10.5" O.D.8.5" Long...Needed .010 shrink and a pretty good weld because these will be "Carbide Coated" and will see major abuse...Rollers..Single root pass..Stitch..Weapon..All welding done with the same set-up..3/32 Red..Argon..(10 scfh)..220 Amps..1/16" 70S-2...Positioner...I have a few more diffrent sizes to do next week.. I get all the fun jobs... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:wHY DO YOUR PUDDLES LOOK RIPPLED ?  Whenever I do steel or aluminum, the puddls or dabs are uniformly smooth like a bubble.  Just curious because i can't replicate, if you hadn't shown the  torch , I would have thought it was a mig weld.  Just shows how much I know...........500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:I dunno????My root passes do the "dime" thing but the weave just come out that way...I don't touch anything in between passes.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Must be the weave thing. will have to try. Is it just for a wider bead?? when using a smaller tung setup??500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:I.M.H.O.A weave or stitch is stronger than 3 or 4 roots on top of one another..And looks prettier also.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Hey Zap, Can you post some pics of some bad welds - just so the rest of us don't feel so incompetent?  Fire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Originally Posted by VipernutHey Zap, Can you post some pics of some bad welds - just so the rest of us don't feel so incompetent?
Reply:aH,  OK then, is there a drawing on the stitch or weave, or is it just that obvious as it looks. Dabs near the outer edges and heat brings puddle across side to side.500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:I can't actually show you so I drew it out for ya..Try starting with this......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:that looks like stairway to heaven!but its a good explanation...My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Didn't you make a YouTube video of that technique, Zap?Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:zap, those are some beautiful welds, bro! Just awesome!
Reply:Originally Posted by Joe HDidn't you make a YouTube video of that technique, Zap?
Reply:is it just me or is there undercut in the third pic in the far right corner????
GMT+8, 2025-12-22 03:10 , Processed in 0.108959 second(s), 18 queries .
