Rivet Nuts
发表于 2021-9-1 00:28:33 | 显示全部楼层 |阅读模式
I'm thinking about using some rivet nuts on an iron bed project.  The nuts would be inserted in some .065 mild steel 2"x 2" tubing.  1/4" x 20 is the size.  Never used these gizmo's, do they work? spin in the hole?  pullout?, any info would be appreciated.Thanks,Ragnar
Reply:A lot of the truck boxes are manufactured with the door hinges fastened on with a type of rivet nut. Seems to work ok in that application.Anything worth doing is worth doing RIGHT
Reply:Ragnar, I'v used them before and had no problems. You need a special tool to install them. Tighten them up like a pop rivet without the pop.Doug
Reply:Guys,Thanks for the info,  McMaster Carr seems to have it all, including a reasonably  priced install tool.Thanks,Ragnar
Reply:Like anything else, they got their good points and the bad. Be careful to not crossthread the bolt or bind it in any way. If you use too long of a bolt and run out of threads and the shoulder hits the nut, you will spin 'em. Use anti-sieze and the right bolts and your ok.
Reply:I had no faith in them. But I bought an old 61 VW Baja bug. The old timer I bought it from made a custom roof rack for spare tires and such. When I removed the rack one day, I noticed he used rivet nuts. I had beat the HECK out of that car. The rivet nuts were still intact the day I sold it years later. If installed and used properly I say they do a decent job.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:We use these things on all kinds industrial machines for all sorts of attachments such as guards and cover panels.They work great and are a fantastic option for installing threads into items that are too thin for taping threads into.Sure they can be cross threaded and stripped out just like any other thread. However if you have the tool to install them they are also as easy to replace as a pop rivet. They wont pull through the metal because they are larger on the back side.Washman
Reply:use em every day by the hand full ,thay work real goodChuckASME Pressure Vessel welder
Reply:a little trick to keep them from spinning in the hole is to use a star looking lock washer under the head of the Riv nut and it also gives it a little more thickness to clamp onto when you squeeze them.just a trick from the aviation world when we use themPeople are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.  Unknown Pro Mig 175Hyphertherm 600Lots of toys at work
Reply:I prefer to use the brass kind with ribs on the barrel, rather than the smooth aluminum ones.WeldingWeb forum--now more sophomoric banter than anything else!
GMT+8, 2025-12-22 01:36 , Processed in 0.079909 second(s), 18 queries .
