Please Post Tig Welding on Sheet Metal
发表于 2021-9-1 00:28:31 | 显示全部楼层 |阅读模式
Im going to attempt my first tig welding on some 22gauge sheet metal this coming monday and id like to see what this is 'suppose' to look like. I have little experience with tig welding at all, but im decent (so id like to think). Im concerned it will be harder then 'thicker' material (3/16'') as it would be easier to burn through with the arc. Input and picture please!edit - this will be steel 22gauge using a miller econotig with 75 argon/25 co2 gasThanks,      Rob
Reply:only use 100% argon when tig welding
Reply:Yeah, that C25 won't work. Your tungsten will not last 2 seconds.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:argon ONLY!and 1/16 tungstonChuckASME Pressure Vessel welder
Reply:I did some 23 guage,  Its tough.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:thanks for the input on the gas
Reply:I don't have anything that thin..Or I would just for laffs...Sorry.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:22GA mild steel is pretty easy with an EconoTIG. You are gonna have her turned all the way down though. I've done a good bit of 22ga stainless with mine, and it's a bit hairy. It's ok when I've got a heat sink behind the weld, but anywhere I can't get a sink I have to switch to AC to reduce the heat input. With stuff this thin you want a really good tight fit with no gap. I usually just fuse thin sheet like that with no filler. You'll need a little though if the fit isn't perfect, I prefer .040" filler. As you know I'm sure, just make quick short 1" or so beads, and skip around. I'll try to get a few pics for you today. They look just like regulat TIG welds, only tiny, maybe 1/8" wide.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:It's hard.  I've done 23g before and it was a very fine line between melting point and blowing through.  Good luck.
Reply:Try this on the thin stuff . . . Start your puddle away from the edge and dip; now drive the puddle to the edge while dipping again; now you can weld the butt without burning through (keep dipping and keep it moving at a fast pace -- the dips will cool the puddle and give you enough material to prevent a hole).The first dips create a slightly thicker area of metal at the puddle you can work with without burning through and you go from there.I'll try to post some pics tomorrow if I can get a few minutes to set some up and take a pic, parameters, etc.My TIG welding sucks but I've done a lot of practice with the thin stuff (it's cheaper as practice scrap).Favorite right now is a Miller Syncro 200.Tons of tools and I blame at least one of them when things don't go right.
Reply:It's easy as pie if you have a good tight fit up. There really is no sense in using filler at all. That is, unless you are a purist type autoboy guy who does the planishing and wheeling.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
GMT+8, 2025-12-22 02:56 , Processed in 0.094891 second(s), 18 queries .
