my weld beads
发表于 2021-9-1 00:28:27 | 显示全部楼层 |阅读模式
what do you thinka but weld weld in a push at 160amp with 7018 dc rods [IMG][/IMG]this is abut weld in a pull direction at 160amp with 7018 dc rod [IMG][/IMG]this is a T joint weld and it is on a push direction 160amp 7018 dc [IMG][/IMG]Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Dont push, you pull 7018.  Other than the valley of slag that is probably hiding under the push beads, looks pretty good.  At 160 amps you are a little on the hot side, so if you ever run out of position be prepared to drop down around 30-50 amps.Have we all gone mad?
GMT+8, 2025-12-22 02:50 , Processed in 0.068997 second(s), 18 queries .
