Can Metal Core (Select Arc 70C-T) weld over a flux core (71 Elite) pass.
发表于 2021-9-1 00:28:25 | 显示全部楼层 |阅读模式
Any responses would be greatly appreciated!!
Reply:Yes, you should be able to weld that metal cored product overtop of the flux core deposit.  Weld deposit chemistries are very similar.  To be safe, I would take a grinder and skim the top of the flux cored weld bead.  Clean the flux core deposit to bright metal, before welding with metal core over top.  This is to ensure there is no slag residue left on the surface.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
GMT+8, 2025-12-22 02:58 , Processed in 0.155424 second(s), 18 queries .
