Will pure tungsten hurt inverter machines?
发表于 2021-9-1 00:28:22 | 显示全部楼层 |阅读模式
In my owners manual (Dynasty) it says pure tungsten in not recommended for inverter machines. Why is this? I tried both 2% and pure and they both weld the same on aluminum. I like the pure better because you don't have to sharpen it.
Reply:It won't hurt it. I seem to recall some advantage on the high end inverters with not using it but forgot what it was.
Reply:I use pure on my TA 185 and it doesn't seem to be any problem.. execpt I don't like the big puddles it makes...ROCK ?
GMT+8, 2025-12-22 02:50 , Processed in 0.067086 second(s), 19 queries .
