car hauler
发表于 2021-9-1 00:28:20 | 显示全部楼层 |阅读模式
I just started on a car hauler this morning around 10:30.  The I-beam was to big for the chop saw so everything was cut with the torch.  I had it rolling at 6pm.  I'll try to get some pics tomorrow, it's to dark now.  It's built out of 8 x 10 I-beam.  It's 16' 4" x 78 1/2".  It turned out about 21" tall, I was gonna put on a dovetail but I don't think I really need it.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Dovetails sure are nice when loading and unloading, what size axles did you put under it?  I've seen HD equipment trailers that were'nt even 8x10 I-beam.
Reply:I love this....Tell us about it...And make us wait for pics.... This is just not fair...   ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:LOL, sorry Zap.  Got dark on me to quick.  The axles are only 3500# but I got the I-beam FREE  It was around 8 sticks 16'4" that I got along with some 4x4 tubing.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:ok littlefuzz, the sun is up here in SC and i know it is in TN too. come on with the pics brudder."Retreat hell, were just fighting in the other direction"Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun  Hypertherm 1000Lincoln sp 1702000 F-450 to haul it
Reply:Hahaaa...I was just about to post the same thing. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Pics or ban Those that say "If it ain't broke, don't fix it" just don't understand!Fast-Cheap-Reliable:  Pick two.
Reply:Ok folks sorry for the delay.  My wife and I were up all night with a sick baby throwing up every 20 minutes.  She threw up blood this morning so we took her to the ER.  Everything's fine now, she's crawling around everywhere now.  Ok so here's the pics, keep in mind this is going to be a work in progress and it's nowhere near finished.  I still got to block up the equalizer hanger cause the shackles are on the frame and it don't any room to move.And I don't even have crossmembers in yet  It's not going anywhere thoughDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Dang must of got a deal on the I beam!AWS CWI Hypertherm 850 plasmaLincoln LN-25Lincoln SAE 400Miller Big 40D28' X 36' X 14' Shop_____________________________________Tools are not the the skill but simply tools!
Reply:Originally Posted by Dipper Welder64Dang must of got a deal on the I beam!
Reply:Nice.  Good start on making it beefy and rigid.  Can't wait to see it finished.
Reply:Looking good,real good!!!Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Looks like you could use another axle to take advantage of that things structural capabilities. Are you going to gusset or box the tounge to frame locations ? Everythings deadended on the front plate, that'll be your weak spot.Anything worth doing is worth doing RIGHT
Reply:Where's the dime?WeldingWeb forum--now more sophomoric banter than anything else!
Reply:You shouldl have put bigger axles on it, with 3500 lbs. axles on that trailer you can say your weakest spot will be the axles.So how well does it pull?
Reply:They move portable buildings with steel trailers built of stuff like that. Axle choice is wide open, 2 are ok, 3 axles- even better. Then you get to pick axle ratings, 2- 5200 pounders is the same as three 3500 pounders, but more stable on the road, and ratings can vary widely, 2k 3.5k, 5k,5.2k, 7k, just a few of many sizes available.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:i mite sound dumb but what do you mean by dovetails? looks great so far and i wish i could het steel like that for freehttp://datingsidorsingel.com/
Reply:I'm gonna put several gussets in the tongue area to stiffen it up.  I used 3500# axles cause I already had them there at the shop.  They need some new seals and tires but should be fine otherwise.  I've only pulled it from the shop to the driveway which is not far and off-road so I don't know how it's gonna pull yet.  It's not really that heavy only around 1200# so far counting the axles.The dovetail is where you angle the back few feet of the trailer downward and I decided that I don't need it.  I was thinking another 2' for the dovetail but if I build some 5' ramps it should be fine.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Dewayne, is this going to be a deck over when its done?WeldingWeb forum--now more sophomoric banter than anything else!
Reply:Originally Posted by 69 chevyDewayne, is this going to be a deck over when its done?
Reply:Looking purdy so far. Should be nice when you're done.
Reply:Looks great, I was almost thinking 2 car hauler...man it's one sturdy unit!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Now that's the start of a trailer!   And free I-beam to boot?   Gussets, cross-rails, decking, ramps, attach axles, wiring, painting, custom lettering inside the side-rails proclaiming that this was custom made with pride by LittleFuzz for LittleFuzz, ...Oh, and since this -IS- WeldingWeb and not just LookAtWhatI-MadeWeb, where are the close-up pics of some of the welds?  With the coin, for a sense of scale and all.   Sorry to hear about the little one being sick.  Throwing up all night long is no fun for kid or parents.  Throwing up blood is -never- a good sign.   note to Sandy in Californ-I-ay,  That's a trailer.  Not piddly little angle-iron.
Reply:maybe when you are not hauling cars, you can haul a grader or a bulldozer around.... or maybe a building...Only 1200#?  I would have guessed WAY more then that.  I had a little boat trailer made out of 3x4 rectangular that weighed in at about 2500#.Tim
Reply:So far how much money do you actually have in that trailer?  I figure paint and bolts may be about it so far.Sorry folks, I swear I'm gonna finish this trailer in the next few weeks.  I've just been working a lot of overtime at my regular job.  I've only got around $150 in this trailer so far since I had everything but the coupler, jack and plug.  I still need tires though.  I'm still debating putting a dovetail on it.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:I like my dovetail trailer very much, makes it so much easier to load cars, mowers, etc. Take your time, we know we all have lives, other than this forum.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneI like my dovetail trailer very much, makes it so much easier to load cars, mowers, etc. Take your time, we know we all have lives, other than this forum.
Reply:Yes...I know, it's on my "to-do" list. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:I'm having a hell of a time finding used 14" tires so I guess I'm gonna look for some 15 or 16" wheels and maybe I'll get some more pics.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Any junkyard should have a ton of 14" tires..You can get them here for around 10$ each used......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-22 02:50 , Processed in 0.086096 second(s), 18 queries .
