6010 for inverters
发表于 2021-9-1 00:28:14 | 显示全部楼层 |阅读模式
i have a ta185 and many knowledgeable welders have told me an inverter has a hard time with 6010 due to the low ocv. was looking at a lincoln catalaog and they make a fleetweld 180, designed for small ac machines with low ocv.am plannin to try it out, wonderin if anyone else has done so..
Reply:If you have ever read any literature on the TA185 it state that it has circuitry to run cellulose type rods.  I haven't had any trouble running any 6010 rods and I've tried up to 3/16" 6010.  The only short coming is that it will not run anything bigger then 1/8" downhill.
Reply:the dynasty 200 welds 6010
Reply:Those welders who said that are probably the same kind who think you need a chopped '71 SA200 to run pipelines.You will be fine running it with the TA185, and even better off with the fleetweld's.Have we all gone mad?
Reply:Nobody ever said to me that you couldn't run 6010 on an XMT304.Think he's confusing inverters (in general) with the Maxstar 150 which doesn't have the OCV for 6010.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Yup, the little guys won't run them. No reason the TA should have troubles.QamuIs Heg qaq law' lorvIs yInqaq puS
Reply:I've welded plenty of carbon steel pipe (6010 root) with an XMT 304 (Inverter power supply).JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by weldbeadi have a ta185 and many knowledgeable welders have told me an inverter has a hard time with 6010 due to the low ocv. was looking at a lincoln catalaog and they make a fleetweld 180, designed for small ac machines with low ocv.am plannin to try it out, wonderin if anyone else has done so..
Reply:I use Hobart rods, but I think Fleetweld 180 is 6011 ?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by SundownIIIThink he's confusing inverters (in general) with the Maxstar 150 which doesn't have the OCV for 6010.
Reply:thanks fer the thoughts,..im sure the comment was made abhout smaller inverters..my ta runs 6010/6011 pretty good, the problem i sometimes get is hard restrikes/sticking..the ta185 has no dig control, the only solution is more heat..
Reply:Originally Posted by weldbeadthe problem i sometimes get is hard restrikes/sticking..the ta185 has no dig control, the only solution is more heat..
Reply:Originally Posted by weldbeadthanks fer the thoughts,..im sure the comment was made abhout smaller inverters..my ta runs 6010/6011 pretty good, the problem i sometimes get is hard restrikes/sticking..the ta185 has no dig control, the only solution is more heat..
Reply:Originally Posted by Jay OHey don't forget you do have the hot start function you can adjust to help with restrikes.
Reply:Originally Posted by weldbeadi am not aware that  my machine has that function
Reply:You can set up to 170% of the main current setting on the hot start adjustment on the TA185.  So if you had the machine set to 100 amps main current, the hot start can go up to 170 amps.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:i thought it wasa max of 70 amps over the setting..do you recall howto access he menu to change settings?i really need to read the book...
Reply:let this be a lesson to all about the horrible effects of tater..i completely forgot  my ta had  the hot start....this am i fingered out how to reset the parameters and boosted it up to 40 ..made a big difference..many thanks.. Attached Images
Reply:Maxstar 150 runs 6010 like $hit, XMT 304 runs it the balls. All depends on the machine. Then again I havent run one of them can long arc it like an old Idealarc 250 or any engine drive.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingMaxstar 150 runs 6010 like $hit, XMT 304 runs it the balls. All depends on the machine. Then again I havent run one of them can long arc it like an old Idealarc 250 or any engine drive.
GMT+8, 2025-12-22 02:59 , Processed in 0.142058 second(s), 18 queries .
