First beads with Squarewave 175
发表于 2021-9-1 00:28:10 | 显示全部楼层 |阅读模式
Here are a few of my first beads with my new machine.   No, that's not undercut, I didn't get the paint cleaned of very well towards the top and that's just burnt paint and shadow I believe.Lean mean TIG weldin' machineSquarewave 175
Reply:did you have a filler??StangnetShop Full Of Stuff. Joey
Reply:Yeah, I did. I got the camera right up on the welds to take the pictures is that makes it easier for you to imagine. Here is what the welds are from. If you were asking about the filler for pointers, or criticisms, elaborate some, i'm open for giving/recieving advice. Lean mean TIG weldin' machineSquarewave 175
Reply:Looks nice and your garage is cleaner then mine.
Reply:Thank you. I try hard on both accounts! The cleanliness isn't bad for a 16 yr old is it?Lean mean TIG weldin' machineSquarewave 175
Reply:Hey Custom where you at in OK? What vo-tech are you attending? Just curious from eastern ok county myself welds look good!Still lookin for Rock!
Reply:Central OK, I go to Canadian Valley.Lean mean TIG weldin' machineSquarewave 175
Reply:Does a guy with the last name Taylor still work up there? He used to be the welding instructor over there. Has a pipe yard down around chickasa(sp?)Still lookin for Rock!
Reply:I believe he is the PM instructor. Maybe?Lean mean TIG weldin' machineSquarewave 175
Reply:He's probably retired by now I think he went from day-time instructor to a position in the administration level. This has been a few years ago.Still lookin for Rock!
Reply:Yeah I think that is him. I believe the guy teaches the PM classes and is one of the high ranking guys, gets us lotsa good equipment . The guy i'm reffering to has a full beard, brown hair, etc. Of course if you havn't seen him in a year or more, that could make that irrelevent!Lean mean TIG weldin' machineSquarewave 175
Reply:what filler metal you were using??StangnetShop Full Of Stuff. Joey
Reply:I was using ER70-S3 and some RG60 i got with my O/A setup.Lean mean TIG weldin' machineSquarewave 175
Reply:cool, i've ordered 10lbs of er70-s2 for $16@ weldingdepot.comStangnetShop Full Of Stuff. Joey
Reply:Wow, that's a GREAT deal. Thanks for the pointer!Lean mean TIG weldin' machineSquarewave 175
GMT+8, 2025-12-22 02:48 , Processed in 0.093096 second(s), 18 queries .
