New guy intro
发表于 2021-9-1 00:28:08 | 显示全部楼层 |阅读模式
Since this seems to be the busiest forum I'll introduce myself here-I go by Chuck U&R - Up and Running !!! - from a web business I had a few years back. Sold Harley parts.I live in NC, near Pinehurst for you golfers out there, and paint new construction houses for a living.For fun I build HD 'clones' do a little machining, welding and play with guns.Here's my toy list -'97 Custom swingarmunder construction, rigid 'steam roller'under construction, rigid shovel headLincoln SquareWave 175HH 175Smithy 3in1New Jet drill press on order.Kimber SS Pro-CarryKimber SS Gold MatchWinchester Super X2and all the associated bills & taxes !!!
Reply:how's that smithy treating you, i get too tempted every time i get something in the mail from them... Welcome to the site, More members more knowledge!!!
Reply:Like everything else - if I where to put in the time, maybe take a class or two I'd probably be better at it.As it is I use it mostly for turning spacers, replacement handles stuff like that.Haven't used the mill much but plan to soon.Would I buy a new one ? NO. Not unless it was a matter of space limitaion and then I'd probably look at a Shoptask.I plan to eventually replace the Smithy with a 'real' lathe and a 'real' milling machine.I'm just starting to look at steel buildings.I'd like a 30'x50' try to keep it under $15K.Anybody with 'metal building' experience out there ?
Reply:New here as well. Hope to learn something and hope to help some people out as well. Here is my shop and a couple of projects I did.T.J.www.tjsperformance.comHere is a shot of the shop. Note this is when I was moving in. Here is the workbench I made. Engine run in stand for BBC and SBC's. Some Harley parts I made. Fabbed a larger turbo shield. Yes this customer is running a turbo.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Nice playroom !Nice work on the SS parts.There's a guy in AZ, I think, goes by Longrider.Runs turbos on 3 or 4 Harleys and swears by 'em.I like the locks under the engine stand.Where did you get 'em ? or what exactly are they called so I can do a search. My welding table wants to wander off at times.
Reply:I got the locks and caster setup at a local metal scrap yard just by chance. I think Grainger has them as well as MSC.   T.J.
Reply:Chuck, I see you are into guns. I have an FFL. I do it only as a hobby. So If I can ever help you out, let me know>
Reply:Good to know an FFL but what could you do for me in NC ?I'm not that familiar with the laws.Could you do transfers out of state ?(I don't know where the lines are here so stop me if I'm heading for deep water.)Chuck U&R
Reply:Chuck, I could not send it directly to you, but it could go to a local dealer. They will usually do that for a small fee, like $25.00
Reply:I mentioned your hobby to a friend -Can you get me a price for a new  Taurus is 651SS2  357 mag. in stainless.Thanx.Chuck Y&R
Reply:Hi Chuck,We got snow here today, I am going to be plowing. I will look it up when I get home and let you know...Thanks
Reply:TJS, I like that engine run stand.  Did you build it from scratch or did you have plans for it?  That would be nice to run engines to check for leaks and break in cams before putting them in the car.Dave
Reply:Chuck, I checked by 2003 catalog. The 2004 did not come yet. But the 651 in stainless w/ fixed sights would be around $300.00 With Titanium fixed sights about $400.00
Reply:Scott -Thanx for the quick reply.I sent a link to my friend so he'll probably see this.I'll let you know.Chuck U&R
GMT+8, 2025-12-22 03:02 , Processed in 0.116198 second(s), 18 queries .
