Supporting aluminum while welding?
发表于 2021-9-1 00:28:06 | 显示全部楼层 |阅读模式
What system do you pros use to hold thin aluminum while tig welding? I sometimes use a copper bar under flat stuff. What could you use to work on a curved piece? Thanks
Reply:For a one time job I've used particle board cut to the proper radius with a bandsaw. clamp the aluminum sheet to it. It smokes and smells a little but it works and is cheap.
Reply:C-clamps, visegrips, slideing clamps (i forget what there called), and sometimes I just lean scrap metal against the peice just so I can tack it.
GMT+8, 2025-12-22 03:09 , Processed in 0.077468 second(s), 18 queries .
