30A spoolgun hookup
发表于 2021-9-1 00:28:02 | 显示全部楼层 |阅读模式
I have the Miller 30 A on a 251. I think I can run that spoolgun off my weldanpowers or an SA 200 with some sort of control box. Anybody know the setup. Also can I do aluminum from these? I'm sure the weldnpower with / CV is OK but don't think the SA200 will work out. Do I need the CV for aluminum?  I believe I can hard wire MIG from either one. Does controller have the gas port for hookup?  Thanks."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2025-12-22 03:11 , Processed in 0.092259 second(s), 18 queries .
