Hinges?????
发表于 2021-9-1 00:27:52 | 显示全部楼层 |阅读模式
In the next few weeks I'll be doing a lot of gates for the back of dump trucks(fall is here!!!) the hinges that I bought in the past don't stand up very well and it's a pain to make them .Does anyone know where I can get some good hinges or a easy way to make them with little play so the gates don't sag ....thanks
Reply:Post a picture or two of what you've tried in the past. Then we won't be telling you to do what you have already done. Also, what size truck? Little one ton or masive tri-axle, it all matters.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:f 250 dump or the 350... dump bodies i forget the name of makers of the bodies i've used 3/4 pipe with 3/4 round stock but lot's of play I've made them out offlat stock with bolts ... just a couple of ways I have made them in the past just looking for more ideas ?
Reply:Buyers products, makes what your looking for. Capeway Beraing has them down here in Plymouth. Or try Madigian, Brake and Clutch, or DeJanna up by you.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-22 03:10 , Processed in 0.090433 second(s), 18 queries .
