AC out of inverter machines ?
发表于 2021-9-1 00:27:48 | 显示全部楼层 |阅读模式
Why is that almost none of the inverter machines have an AC side ?I'm sure there's a simple reason, someone edjumucate me ... I mean it seems simplistic to me, the machine is powered by AC afterall ... - jack
Reply:Invertec 205, Dynasty 200??
Reply:Reread my post I said "almost none". I did not say all ...I'll rephrase it for you. Why is it none of the low end inverter machines don't have AC ? - jack
Reply:Expense.  It takes two inverters running opposite polarity to get AC, and then the switching circuitry to handle it.
Reply:And don't forget the T/A 185 or the Esab 161, as both have AC.
Reply:Originally posted by Aaron Expense.  It takes two inverters running opposite polarity to get AC, and then the switching circuitry to handle it.
Reply:Maxstars are DC only.  For less than $1500 you can get a complete Esab kit, or for about $1700 a complete T/A kit.  My preferance, for any who might not already know: get the T/A.  I miss mine still (i'd miss it more if I hadn't replaced it with a MM251 ).
Reply:hey jackHow's that Hi freq box workin out for ya???Shane
GMT+8, 2025-12-22 03:10 , Processed in 0.097976 second(s), 18 queries .
