Tig weld pic
发表于 2021-9-1 00:27:47 | 显示全部楼层 |阅读模式
I was bored the other day.   Attached Images
Reply:i welded a sawzall blade together the other day, worked pretty good too until i jammed it...  this was out of boredom too!!!StangnetShop Full Of Stuff. Joey
Reply:Try a razor blade, actually try welding as straight as you can again and again.J P Streets Welding LLC
GMT+8, 2025-12-22 03:11 , Processed in 0.104847 second(s), 18 queries .
