Argon Gas Cylinder Valve Problem
发表于 2021-9-1 00:27:42 | 显示全部楼层 |阅读模式
When I bought my used TIG welder it came with a 300 cu. ft. argon tank. I tried to use it the other day and the valve is faulty (guessing by the weight that there is actually gas in the tank).The tank seems full and was sold as such, but nothing comes out if the valve is open.  I've put a regulator on it as well and no gas. Am I missing something or do I just have a cylinder with a bad valve? What can I do to repair besides trying to take it somewhere to empty and replace the valve? It's likely a rental tank because there is a name stamped on the collar, although the name doesn't come up under a google search. Ideally, I'd like to trade it in for some credit on a refill or at least use the gas.Last edited by bluduk15; 09-15-2010 at 12:30 AM.
Reply:Nothing comes out of the valve, and you think it "seems full"?  That's a good one.Have you considered that it might be empty?
Reply:Yes, I've considered that. But, guessing by the weight, it feels full. (edited OP to clear that part up)Last edited by bluduk15; 09-15-2010 at 12:36 AM.
Reply:An empty 300CF cylinder should weigh -around- 135lbs.  That's not so light on its own.300CF of argon adds just over 33lbs to the weight (if that were helium inside, it would only add 3.3lbs, so yeah, argon is kinda heavy).You have a scale?  I don't think I could tell the difference between 135lbs and 168 by just feeling it.I know that if I leave the valve open on my argon cylinder (granted, its only 80CF), even with the valve stopping the flow in my welder, it will be empty overnight.
Reply:Make sure the valve wheel/handle....the flower looking thing you turn is not stripped, or  the valve stem is not rounded off. To do so, remove the wheel/handle....buy removing the little nut in the middle. Place a wrench on the square stem and turn. If nothing happens, it's empty.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Originally Posted by waginMake sure the valve wheel/handle....the flower looking thing you turn is not stripped, or  the valve stem is not rounded off. To do so, remove the wheel/handle....buy removing the little nut in the middle. Place a wrench on the square stem and turn. If nothing happens, it's empty.
Reply:The cylinder has a Tare weight (empty weight) stamped on it somewhere.OAdoctorwww.regulatortorchrepair.com
GMT+8, 2025-12-22 03:09 , Processed in 0.107755 second(s), 18 queries .
