Armor for Pipe Welding....
发表于 2021-9-1 00:27:41 | 显示全部楼层 |阅读模式
So, when welding either 5G or 6G I keep my left elbow against the pipe to stabilize my operation. But in doing so, I always end up laying the back of my left glove against the newly laid weld/slag....that **** hurts after completing my weld.Ive got Tillmans with kevlar in that area, but where can I grab an external hand and sleeve protector, anybody have any thoughts for or against??Thanks, MaxLincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Originally Posted by MadMax31Ive got Tillmans with kevlar in that area, but where can I grab an external hand and sleeve protector, anybody have any thoughts for or against??Thanks, Max
Reply:They make a rectangular pad that is held behind the glove with an elastic band that goes around your hand.  My LWS has them.Tillman also makes an extreme heat glove with a snap on version of this pad, that can be bought for just the left hand (that glove is also aluminized to reject more heat).
Reply:As the rod burns down, you need to learn to drop that hand down / away, and take control of the stinger with one hand. It will be cumbersome at first , but well worth it in the long run!Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPAs the rod burns down, you need to learn to drop that hand down / away, and take control of the stinger with one hand. It will be cumbersome at first , but well worth it in the long run!
GMT+8, 2025-12-22 07:53 , Processed in 0.087343 second(s), 18 queries .
