查看: 13|回复: 0
Auto tink mask acts funny on AC
发表于 2021-9-1 00:27:40 | 显示全部楼层 |阅读模式
Just tried welding a few beads on aluminum for the first time tonight, and the freakin welding mask sometimes does not tint?  Its brand new cheaper one, works fine on DC welding, but when in AC on alu, it wont go sometimes, so I put the sensitivity to max, and it will tint when I look at a light, and almost all the time it will tint when I strike and arc, but the odd time it didn't?  What gives.
Reply:Sometimes auto lenses won't sense the tiny high frequency arc starter, but it should be sensing the actual welding arc itself.  Maybe you're blocking the sensors with your other hand or something?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33Sometimes auto lenses won't sense the tiny high frequency arc starter, but it should be sensing the actual welding arc itself.  Maybe you're blocking the sensors with your other hand or something?
Reply:bet your helmet has a fast and slow delay switch, try the other setting also might have a sensitivity setting , try the otherwhen i switched from ac to dc then back i was always playing with itforney f100 220vmiller thunderbolt 225v a/ccampbell hausfield flux welder 115vcraftsman o/a rig(harris)collosal tech plasma cutter 50amp
Reply:I know the auto tint helmets are nice but i have to say i went to a fixed shade helmet with the large 4.5"x5.5" lense and i will never look back at a auto dark helmet for tig welding for the same reason you are having problems with.   The helmet i bought was a jackson and it was like 30 bucks . Very nice lightweight and never needs batteries or charged.
Reply:Thats why I like my huntsman 951P, no batteries to charge, tints everytime, no sensors or dials to play with and If it breaks oh well I'll just have to pick up another one for 20 bucks.
Reply:Originally Posted by SPGbet your helmet has a fast and slow delay switch, try the other setting also might have a sensitivity setting , try the otherwhen i switched from ac to dc then back i was always playing with it
Reply:Some cheaper hoods just get confused on AC. Get a fixed lens, or try for a better hood. Your eyes are important.UA Local 598
Reply:Originally Posted by WHughesSome cheaper hoods just get confused on AC. Get a fixed lens, or try for a better hood. Your eyes are important.
GMT+8, 2025-12-22 03:13 , Processed in 0.075060 second(s), 18 queries .
