Heat exchangers Part II
发表于 2021-9-1 00:27:39 | 显示全部楼层 |阅读模式
Here are the jobs in progress.  First clean off all stuff including old weld.  Leave customers tack in place.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Weld up to the tack on both sides, Grind tack away and finish the bead.  I used a pretty good overlap to start so I had a good puddle by the time I got to the end of the last bead..  Here is the Big gap one finished.  One pass. It was over 3/8" in the center.I did not but the L bracket on. Last edited by David R; 10-10-2007 at 07:15 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:a little closerI am not a stack o dimes fan, its just how it came out.  I was using a huge U weave..030 Er70S-6, AG8, 225 ipm 18 volts.  Invertec V350 pro.  Inductance on +2 about 100 amps.  1 1/8" to 1/8" most of them fillets.  Poor fitup!This is where the 3/8" nut was in heat exchangers part I.DavidLast edited by David R; 10-10-2007 at 07:32 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Looks good man!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:You would win, if I were judging a welding contest.  Looks goodSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:David, those heat exchangers are becoming a neat project for you!! It looks really good, especially considering you are stuck having to fill a gap up to 1/8" in one pass like that. Good job on keeping it from warping too much.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2025-12-22 03:09 , Processed in 0.087546 second(s), 18 queries .
