Wire????
发表于 2021-9-1 00:27:33 | 显示全部楼层 |阅读模式
What brand of wire and what size is best?
Reply:That is an impossable question to answer. What are you doing?MillerMatic 175Thermal Dynamics Drag-Gun PlasmaAirco Bumblebee AC/DC SMAWVictor Super-Range II oxy/act
Reply:For bailing hay, twyne seems to work best.For holding the muffler back on the car till you can get home & weld it, coathangers.For conducting electricity, copper.For tieing rebar, Iron mechanic's wire.For MIG welding, it depends on the base metal and process.Appreciation Gains You Recognition-
Reply:Sorry...What I should have said is what brand of wire in general do you all prefer? Is there one company that makes better wire than the rest?????
Reply:I have tried many different type, but I like Lincoln L-56 for welding mild steel.
Reply:L-50"after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:on flux core it's e71t-gs, nr-211 just doesn't seem to fuse well for meStangnetShop Full Of Stuff. Joey
Reply:the GS is single pass right?A true democracy is two wolves and a sheep voting on what's for lunch.
Reply:Typically there are for mild steel ER70S2 thru  6. ER70S6 having more silicon will flow a little better.J P Streets Welding LLC
Reply:Originally posted by Crithpy_Critter the GS is single pass right?
Reply:thanks dan , i wondered what that meant, i knew it was E>electrode,71>chem?,T>tubular. not sure on the 71 though...StangnetShop Full Of Stuff. Joey
Reply:Originally posted by vipermanz thanks dan , i wondered what that meant, i knew it was E>electrode,71>chem?,T>tubular. not sure on the 71 though...
Reply:thanks dan!!, it's good to have more knowldege on welding!!StangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-22 03:08 , Processed in 0.068967 second(s), 18 queries .
