Wire-Feed wire . . . .
发表于 2021-9-1 00:27:33 | 显示全部楼层 |阅读模式
Yup...another question from your favorite undertaker:Regarding the wire i use in my hh135.....i've been using E71T-GS(.030").....until i decide to take the dip and get a gas bottle,is this a good wire to use ?....or could someone makea better recomendation ?I'll be the LAST one to let you down !
Reply:.030 will be a good all around size of wire. Yet for a thin metal application .023 will of course be better for you then.J P Streets Welding LLC
GMT+8, 2025-12-22 03:12 , Processed in 0.100039 second(s), 18 queries .
