dealing with pot metal- how?
发表于 2021-9-1 00:27:29 | 显示全部楼层 |阅读模式
don't know if this is the right place to ask, but thought I'd throw it out there..  my headlight buckets on my 66 mustang are pot metal and there's a couple of small brackets that need repair.  Since the melting point is probably pretty low, mig is out of the question and I think my only option is soldering or brazing.  My question comes down to what type of filler do I use?  and where can I get it?
Reply:Mig and tig dont work, that much I can say from experiences.  Maybe brass brazing would work.  When something's pot metal, I just throw it away and buy a new one....MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:There are a couple of productshttp://ezinearticles.com/?Welding-Po...fix&id=2663783http://www.muggyweld.com/Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:[ame]http://www.youtube.com/watch?v=8oZ_YElZk_Y[/ame]Cigweld Transmig 265seBoc 140amp StickBoss 200amp AC/DC TIGLincoln Electric Invertec V260-S
Reply:We have used Aladdin 3-in-1 Rod... (TIG welded)... for repairing pot metal for years.Its not real pretty but it works...Steve1946 Shorthood  -  1958 Blackface  -  1962 Redface  -  1967 Redface  -  1968 Redface -  1970 Blackface  -  2005 300D -  2008 Vantage 300  -and a ton of other welding stuff
Reply:We use Aladdin 3-in-1 Rod...(TIG welded)... to repair pot metal.  Been using it for years, its not real pretty, but it worksSteve1946 Shorthood  -  1958 Blackface  -  1962 Redface  -  1967 Redface  -  1968 Redface -  1970 Blackface  -  2005 300D -  2008 Vantage 300  -and a ton of other welding stuff
Reply:deleteLast edited by C6.7weldrig; 09-20-2010 at 10:01 PM.Reason: double post...Steve1946 Shorthood  -  1958 Blackface  -  1962 Redface  -  1967 Redface  -  1968 Redface -  1970 Blackface  -  2005 300D -  2008 Vantage 300  -and a ton of other welding stuff
GMT+8, 2025-12-22 03:09 , Processed in 0.105077 second(s), 18 queries .
