tips for gmaw
发表于 2021-9-1 00:27:27 | 显示全部楼层 |阅读模式
Lincoln 180t, 75 25 gas, .025 lincoln wire, Seems to be crackling rather then sizzling. Tried different gun angles and stick out. Gas flow is 20 lpm.
Reply:Is the gas Flow really 20 LPM that is about 40 CFHway too much gas flow for what yer doing.On the tapped machines you can only change the wire speed while welding so select a Tap and then mess around with the wire speed.Clean metal?oh and also Contact-Tip-to-Work-Distance makes a difference.Last edited by Broccoli1; 09-22-2010 at 07:49 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Figured it out operator error. Gun hose was not seated all the way in. Must have been not getting any gas. Thanks for the help.
GMT+8, 2025-12-22 03:09 , Processed in 0.096790 second(s), 18 queries .
