+20 ridged swing arm
发表于 2021-9-1 00:27:22 | 显示全部楼层 |阅读模式
material used  1.000 by .065                   .875by .065                   .750by .065                   .750by .049Strive For Perfection
Reply:How long does it take to mock up that and then to final all the welds.........  Wjat do you use to come up witht he design or is that already done for you?  Some tight fit up.500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:Some pics of your jigs or fitting tools would be good too.........The joints look machine preped they are so tight. I know it takes me atleast 20 minutes per end to fit up that tight.500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:Originally Posted by PLUMMERSome pics of your jigs or fitting tools would be good too.........The joints look machine preped they are so tight. I know it takes me atleast 20 minutes per end to fit up that tight.
Reply:not tryin to jack your thread but are you doin some fab work for someone's truck frame?...i ask that because the work on this particular frame is beyond badass and i was curious if this is the same "morbid fab" he took his to
Reply:very nice work as always brooks
Reply:very nice work. by the way what is it for?http://datingsidorsingel.com/
Reply:Make it a little longer and you'll have a Hi-teck wheelie bar!  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by railin93not tryin to jack your thread but are you doin some fab work for someone's truck frame?...i ask that because the work on this particular frame is beyond badass and i was curious if this is the same "morbid fab" he took his to
Reply:Originally Posted by zapsterMake it a little longer and you'll have a Hi-teck wheelie bar!  ...zap!
Reply:Originally Posted by cheeseclipvery nice work. by the way what is it for?
Reply:Originally Posted by BrooksWhat kind of truck?
Reply:what do you listen with that stereo man? It sure gets you some inspiration!Do you make calculations for the design? What bender do you use for those bends? That´s Ti right? Thanks My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Originally Posted by elvergonwhat do you listen with that stereo man? It sure gets you some inspiration!Do you make calculations for the design? What bender do you use for those bends? That´s Ti right? Thanks
Reply:could we see the calcs? engineering student in here My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Originally Posted by elvergoncould we see the calcs? engineering student in here
GMT+8, 2025-12-22 07:53 , Processed in 0.184379 second(s), 18 queries .
