Self-Shielding Wire
发表于 2021-9-1 00:27:18 | 显示全部楼层 |阅读模式
OK guys....here's a little "For your information" stuff from yourfavorite undertaker.   I've read some threads regarding different brands of wire....so here's my 2 cents worth.I just put a new spool of Radnor E71T-GS (.030") in theHH135....and I'll tell you this:  It runs sweeter than any wire I have used so far ! (and i've tried 2 or 3 different ones).....Radnor, evidently is a private brand of Airgas, but my welding guy told me it's made by Lincoln....(and it say's "made in USA") !The bead is not quite as "shiny" as the stuff i got from Tri-Tech,after you chip it, but I assume it's up to the standards forE71T-GS.   It sure welds nice !....No "snap, crackle, pop"......just a nice, smooth "Hiss".Good penetration & good appearance !  What more could you ask for !  I'll be the LAST one to let you down !
Reply:if its made by Lincoln , its got to be good.I read somewhere, that Lincoln made the best wire.  Some independant guy, i use Lincoln wire and happy with it.There's a method to the madness, disregard the method and the madness begins!!
Reply:Thanks, Big Rig !.....I don't own any Lincoln equptment at the present time, but I believe that if one sticks with NAME-BRANDstuff...(Miller, Lincoln, Hobart....)  you can't go wrong !I'm not brand-loyal....all my stuff is Miller/Hobart now,....(and i'm very happy with it).......but if I ever deceide I want a diesel....That Pipeliner 200dwill be mine !I'll be the LAST one to let you down !
Reply:Marko,That's good to know. I've never used any other (yet). The first spool (10lb.) sort of gave me fits, but then the welder was brand new to me also. The second spool was like a brand new world. I actually went and cross checked the numbers to make sure it was the same wire. Maybe the first was a less quality run or something. I'm on the third spool and think it's great. If it can work for me it's gotta be fool proof.
Reply:glad to see that there's another e71t fan!!!StangnetShop Full Of Stuff. Joey
Reply:is that multi or single pass?
Reply:I believe it's single pass I'll be the LAST one to let you down !
Reply:ALSO.......Lincoln E71T-11 works real nice, (I have no idea what the difference is, though)  I'll be the LAST one to let you down !
Reply:GS is single pass wire.StangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-22 03:08 , Processed in 0.091264 second(s), 18 queries .
