What Welder For My Purpose
发表于 2021-9-1 00:27:11 | 显示全部楼层 |阅读模式
Hi all,I'm a welding newbie... did a little gas welding when younger but that's about it. I'm looking for a stick or MIG welder, initially to weld chain onto 1/2" and 3/8" thick steel plates. Also need to weld some 1/2" steel rod onto steel fence posts.Will a welder like a Lincoln 225 be sufficient for this purpose? I'm confused about this because 220V welders don't usually seem to be rated for 1/2" thick materials? Any advice is much appreciated!Thanks,Jimmy
Reply:If you are talking about the 225 amp buzz box for stick welding, do yourself a favor and get the AC/DC version instead of the AC-only.  Stick runs much nicer on DC.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-22 04:50 , Processed in 0.096224 second(s), 18 queries .
