MM 250x ?
发表于 2021-9-1 00:27:10 | 显示全部楼层 |阅读模式
I found a 250x for sale locally. It is the late model 250x with volt and amp readout.In good shape cosmetically.Comes with 125cf cylinder for 600.00.If it test out ok should I bite.I know about the 250 issues but I have read that miller got better with each generation.250, 250x no meters and 250 w/meters. What do you think? Thanks, Ken
Reply:My buddy works at his family owned diesel repair shop and has in the past done go kart racing, late model racing, 4wheel drive customizing and now has a rock crawling buggy. They use the earlier 250 for all the welding in the shop and all the hobby repairs, besides it makes a weird noise when cold it welds just fine and has burnt a lot of wire, with no down time.If it was me I would try all the different settings and lay a lot of beads down and really test the thing out, you would be lucky to find a 251 or 252 anywhere close to that price.
Reply:Thats not to bad of a price. I would still offer him $500 just to see if he would come down any.
Reply:I had a used MM250. Meters would be a nice touch.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:i have a 250x, got it for 500 bucks a few years ago..... it's run countless rolls of wire without checking upnothing fancy, just a few hot glue guns for metalwww.sicfabrications.com
Reply:I also have a 250x mine got the meters,i have done nothing to it, but run it hard for 10 yrs and never had 1 problem.
Reply:Sounds like a good deal to me.  My friend has been using a MM250 in his shop for years without problems.  The arc is too stiff for my taste, but I've welded with it and it welds fine.  It does have a rather narrow range of acceptable volt/wfs adjustment, similar to my MM175, unlike the very wide sweet spots of my Passport and HTP.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I picked it up after testing and talking him out of a spare co2 tank.600.00 it needs cleaning and if I keep it I will paint it. My lws traded me a tank of c25 even for the co2 tank and a safety cap. Attached Images
Reply:Not bad for 6 bones.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Paint it? I wouldn't, looks pretty good from here.Great deal, that welder would probably still go for over $1200 here."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
GMT+8, 2025-12-22 07:51 , Processed in 0.090315 second(s), 18 queries .
