Insert Picture into Message
发表于 2021-9-1 00:27:09 | 显示全部楼层 |阅读模式
I cannot find directions for this.  I can only find "insert image" which asks for a URL and does not seem to be able to move a file from the local disk to the mesage.   How do I insert an image into a message?Can't find this in the FAQ either.Rob PageMiller Bobcat 250Lincoln SP170-T
Reply:Rob click on the Gem clip, and upload your messages, and close the upload box.  Then click on the paper clip again, and it will ask which images to insert.  Hopefully that makes sense.  ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Hahaa, say what Jackson? Are you talking to your son or dog when you're typing and inserting their name?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Test photoWow.  So easy, yet so un-intuitive!!!!!Thanks!!  Now to go do the real post.Rob PageMiller Bobcat 250Lincoln SP170-T
Reply:Originally Posted by Rob PageI cannot find directions for this.  I can only find "insert image" which asks for a URL and does not seem to be able to move a file from the local disk to the mesage.
Reply:Does that work for avatars too, or do the have to be hosted off-site ?Anything worth doing is worth doing RIGHT
Reply:You should be able to host avatars here.  I don't see why not.  As long as thye are the right size and dimension.
Reply:Thanks WelderBoy..as you can see it does work.Anything worth doing is worth doing RIGHT
Reply:Is that your portrait?
Reply:As a matter of fact it is...lol.. My wife painted a full size oil for a customer a few years back, we thought that this detail shot closely resembled my mug...lolAnything worth doing is worth doing RIGHT
Reply:Thanks Welderboy.  I'll check it out.Rob PageMiller Bobcat 250Lincoln SP170-T
Reply:Originally Posted by olddadAs a matter of fact it is...lol.. My wife painted a full size oil for a customer a few years back, we thought that this detail shot closely resembled my mug...lol
Reply:You haven't read my profile have you Sandy...lolAnything worth doing is worth doing RIGHT
Reply:Originally Posted by zapster  Now all you need to do is post it in "Faces to Names"   ...zap!
Reply:Hi !I'm trying to publish a foto...Im following to  follow  the above instruction, without sucess. Someone may give step by step instructions ??Thanks John
Reply:Follow steps in the pictures... Attached ImagesLast edited by OldFatGuy; 09-25-2010 at 05:36 AM.
Reply:Originally Posted by Rob PageI cannot find directions for this.  I can only find "insert image" which asks for a URL and does not seem to be able to move a file from the local disk to the mesage.   How do I insert an image into a message?Can't find this in the FAQ either.
Reply:I must be slow... an Old Fat Guy beat me to it!!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Look again Paul - olddad's post is over 3 years old.Hmmmm.  Why can't we delete a post when we make a mistake? Last edited by duaneb55; 09-25-2010 at 11:22 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I just hit the paperclip above where you post and it opens a browser box...Browse..Insert..Done....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Rojo,why are you not able to access the Images on the MAC? Iphoto should have all your images.I know mac has lots of proprietary crap they imbed on the Image once it is in Iphoto so if you burn a Disc from Iphoto PC's may not be able to open them. BUT if you drag the Image out of Iphoto in to a regular Folder or on to the desk top, then burn a disc from there PC's will read them.I just put everything up on P Bucket and just Link from there.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by duaneb55Look again Paul - olddad's post is over 3 years old.Hmmmm.  Why can't we delete a post when we make a mistake?
Reply:1- Put the picture or image in your C: drive,   ie C:/my picture/photo.jpeg2-Opem the forum and open the " thread " section,3- Click the " attachements", (it is shown as a PAPER CLIP in top of page ) 4- Fill the field  "Upload File from your Computer" with the image file and path,  (ie C:/my picture/photo.jpeg)5- Click "upload" and continue to typing the mesage Done ! Attached ImagesPLANS FOR THE BASEMENT SINGLE LINE.pdf (18.0 KB, 14 views)I've not tried putting pictures within the text before, or at least in a long time. Suppose I needed some new copper-coated carbon  stuck in here; wouldn't they be too big to fit or burn the post to pieces?I haven't gotten them yet, so right now they are still a figment of my (greedy) imagination.How can I not have them if they're actually here? No, I have not been drinking...
GMT+8, 2025-12-22 04:49 , Processed in 0.094137 second(s), 18 queries .
