water tanker
发表于 2021-9-1 00:27:08 | 显示全部楼层 |阅读模式
here the water tank that has caused me so much pain. cutting the bottom out and going to refab and raplce the baffles inside. i will be rolling the new belly plates in the AM. will post when i get them uploaded."Retreat hell, were just fighting in the other direction"Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun  Hypertherm 1000Lincoln sp 1702000 F-450 to haul it
Reply:Wow - with surgery that intense it almost seems like time for replacement of the entire thing rather than repair...  That's a serious project!
Reply:Is that about 3/16ths or so??
Reply:yes, 3/16. i am replacing with 1/4". a new tank is 58 grand, and i will have a new one done for around 9k. boss says there will be a bonus in it if i get it done soon. a new tank doesn't come with any plumbing or the mounting hardware. so i decided it was easier to rplace the bottom half and all the insides that cut the tank loose from the tractor and slide a new on in."Retreat hell, were just fighting in the other direction"Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun  Hypertherm 1000Lincoln sp 1702000 F-450 to haul it
GMT+8, 2025-12-22 06:20 , Processed in 0.092994 second(s), 18 queries .
