off the wall carpet cleaning van fab
发表于 2021-9-1 00:27:07 | 显示全部楼层 |阅读模式
First pic is the finished rear spool mount w/ reelThe last few pics are the makings of the other reel to be suspended from the top of the van roof support structure for another reel............not yet installed;however tomorrow will be donethese were a bit tougher w/ the option of sliding and swivel of the hose reel post more later of the finished project  weld it like you own it
Reply:intersting space-saving idea. good job... it looks like it came from a reel company (no pun intended).later,Andy
Reply:Now the cieling reelSuch fun.............. weld it like you own it
Reply:that´s great man!can we see what else you got inside?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:You know that the structural integrity of that roof bow is on the adhesive bonding it to the roof sheet?  Break that bond and the bow becomes pretty flimsy.  Maybe not now, but perhaps after a few hundred hard tugs on the air hose?WeldingWeb forum--now more sophomoric banter than anything else!
Reply:Heres the deal ...the adhesive only creates a bond to the cross member....the cross member is by no means supported by the roof...... The  wide span of the bracket distributes the weight perfectly.  It was tested for 175lbs.  Spool assembly weighs 38lbsCustomer requested this design.......so he is always right weld it like you own it
Reply:looks goodStrive For Perfection
GMT+8, 2025-12-22 04:49 , Processed in 0.069867 second(s), 18 queries .
