Maxstar 200 STR DIG control
发表于 2021-9-1 00:27:00 | 显示全部楼层 |阅读模式
can't get the DIG control set right.6013 rod set at 110 Amps and trying to weld 1/2 inch sq. rod together.DIG control set at 30 and if I get too close with the rod it blows the metal out of the weld.DCEP is the setup.  If I set the DIG lower, I tend to stub the rod and lose the arc.maybe I need to hire a weldOr.A true democracy is two wolves and a sheep voting on what's for lunch.
Reply:Crithpy,that's a brilliant question....I think what you should do is turn the amps up and put up with the spatter until you can get some 7014 rods to practice with.A true democracy is two wolves and a sheep voting on what's for lunch.
Reply:why that's a brilliant reply,I'll do that.A true democracy is two wolves and a sheep voting on what's for lunch.
Reply:cripthy, did you take your meds this morning ??????
Reply:.............................. Attached Images
Reply:Lord Jack where did you come with that
Reply:I tell yall this pregnancy thing is effecting Jack something serious.Next he'll give up welding for wall stenciling in the nursery.I can just see it now, a pink room with little propane cylinders stenciled all around the ceiling.Appreciation Gains You Recognition-
GMT+8, 2025-12-22 06:20 , Processed in 0.092343 second(s), 18 queries .
