查看: 2|回复: 0
Thank's Franz...........
发表于 2021-9-1 00:26:59 | 显示全部楼层 |阅读模式
Just wanted to make a public "Thank You" for the info. you typedon the nozzle size.   I understand completely now !I've been trying to force too much heat through too smalla nozzle !   When you said: "Put the coal to 'er"...I thought thatcranking up the pressure was the answer......Now I know thatthe nozzle size is very important !  Every nozzle has it's "Sweet-Spot"....not enough pressure, and the nozzle will not give you all that it's able to deliver....but if you force it,  you loose the "Soft" flame that you are trying for !   Thanks again ! I'll be the LAST one to let you down !
Reply:Yeeha, I got one right!! Can I do it over?Appreciation Gains You Recognition-
Reply:Where is that thread?This is all I can find in this forum:http://www.weldingweb.com/vbb/showthread...ht=nozzle+sizeAhh, I found it:http://www.weldingweb.com/vbb/showthread...ghlight=nozzleI can't delete my own damned posts so here is my mistake for all to see!I searched  'nozzle size' instead of just 'nozzle'Last edited by rusted; 02-27-2004 at 02:48 AM.
GMT+8, 2025-12-22 04:52 , Processed in 0.074009 second(s), 18 queries .
