welding pot metal or cast aluminum
发表于 2021-9-1 00:26:55 | 显示全部楼层 |阅读模式
i would like to know if it is possible to weld the side case on a briggs and stratton engine which was cracked due to over tightening the bolts i think its made of pot metal or cast or something of that nature i only have an ac lincoln welder but i was told there is a rod that you use for welding all metals anyone know if there is such a thing?
Reply:That case is aluminum.A repair to the case requires TIG-not stick.Blackbird
GMT+8, 2025-12-22 07:51 , Processed in 0.070466 second(s), 18 queries .
