powcon 300SM
发表于 2021-9-1 00:26:54 | 显示全部楼层 |阅读模式
Does anybody know data sheet for SCRs used in powcon 300SM?What tipe of SCRs is used or anything that can help to identify SCRs))Thanks to allGogo
Reply:Contact these folks.  Ask for Eddie, he's the tech.  www.arcproducts.comMM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:ty,brother but stil have ho answer
Reply:It's not a data sheet but does the parts break-down in this manual http://www.arc-products.com/literatu...dels/300SM.pdf help any?Manual pages 32 & 33, item #3.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I have it ,but thanks ,however,need desperatly datas of SCRs)
Reply:Maybe this http://www.industrial-electronic-rep...php?postID=946 will help.  ??It's an old thread/post but the contact info may prove positive.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If you are looking for the large hockey puk SCR's. Arc products sells them as a matched preassembled pair. with the heat sinks. You might be able to read the numbers on the diode, then go to the NTE electronics web sitelook for the cross reference and enter the numbers. If they cross to an NTE scr you can get a part number and the spects.also try doing a web search on just those numbers. You might find what you are looking for and several places to buy it.
GMT+8, 2025-12-22 04:41 , Processed in 0.089845 second(s), 18 queries .
