can i purchase the aluminum welding rods from a local hardware store and weld an aluminum crank-case cover for a small engine with those rods or am i going to have to spend the 85.00 and have it tig or heli-arched? anyone have any idea's a local welder here said he would heat the case up with a torch and wire feed weld it! wow i don't believe that would work thanks for all ya'lls help i have a lincoln 225 ac welder but no clue as to what if anything i can do with thatLast edited by loudlarry; 10-04-2010 at 02:15 PM.Reason: adding more definition
Reply:This guy makes Al stick welding look easy, not.http://weldingweb.com/vbb/showthread.php?t=45197
Reply:A small engine casting is way too thin to try to stick weld it my opinion.Tough as nails and damn near as smart
Reply:Tig is the only way I would attempt it. Got pics?Here is a few I've repaired.http://weldingweb.com/vbb/showthread.php?t=38698My name's not Jim....
Reply:Spend the money and have it tig welded.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
