Broken bolt removal
发表于 2021-9-1 00:26:50 | 显示全部楼层 |阅读模式
Had a friend call me yesterday and wanted to know if I could remove a couple or bolts that were broken off in his dozer, told him I'd be there first thing in the morning, Got him fixed and he was good to go.The welds aren't that pretty as that was not a requirement. The requirement was that they hold up to a 3/4" impact wrench till the bolts came out. Here are a few pictures, not real clear as all I had was my cell phone camera.Here goes, first picture is after 1 removed working on second one. Second picture is after they are removed laying on the plate they hold in place. Hard to tell by the picture, they are 3/4" fine thread.Last edited by David R; 11-02-2007 at 05:11 PM.
Reply:Thanks for the Pic's
Reply:You know you have penetration if they put up with an Impact Gun.. Good Repair!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice job, I do that a lot.I fixed your pics.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Good job man My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Good job, thats the wy I do broken bolts my self.
Reply:Thanks for the good words.Thanks David for fixing the pictures, I have to learn how to do them that way. For me puters are not nearly as easy to use as welders.
Reply:I hate playing that game, usually they are caked in mud, grease, and stupidity.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Do you stick a nut on the broken stud and weld through the opening? What prevents your weld puddle from sticking to the internal threads and binding the stud even more in there?
Reply:Are those washers under the nuts?
Reply:working in a machine shop I remove a lot of bolts pipe plugs and broken taps. Nice work. What did you use heli-arc? That is what I use and some 347 ss rod.
Reply:He welded a flat washer onto the bolt, then a nut onto the flat washer.  Works MUCH better than trying to weld inside a nut.
Reply:Aceman has it, exactly the way I did it. Used Stick and 7018 rod.
Reply:Bolts on tractors never break :P***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
GMT+8, 2025-12-22 07:51 , Processed in 0.068723 second(s), 18 queries .
