Newbie with some crappy pics
发表于 2021-9-1 00:26:49 | 显示全部楼层 |阅读模式
Pics are from my camera phone but give you an idea.  The first is a pic of a stainless steel tig weld(kind of blurry).  The other two are just an example of some of the kinds of things that I make at work.  This particular one started out with a 1/4 blank in the center cut into that shape.  I then had to use 2 pieces of 1/8" two make up the side thickness and form the shape around.  Those were built by hand just forming the pieces around as I went along.  Then welded the seem of the 2 1/8" pieces and ground the whole thing smooth.  That was just one of them, I had to make 4 of them in total that all had to match one another. Attached Images
Reply:You need a better camera But those look like some nice welds. Were does this piece goes into?what processes did you use for making the parts?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Yeah camera phone suck!  The first piece was a caster plate for a tubing fixture for Kohls department stores.  And the second and third pick were also for Kohls and was a base for another store fixture.  Those were all TIG welded, is that what you meant by what process?
Reply:yeah but I was referring to cutting mostly =)nice workMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Center template was laser cut out of 1/4", the 1/8" pieces I sheared up long and then formed them around by hand and then just cut of the excess and welded the seem up.
Reply:newbie hahuda, thats funny those look professional (although pics aren't very good)
Reply:Newbie to the site, not welding.
GMT+8, 2025-12-22 04:40 , Processed in 0.088904 second(s), 18 queries .
