mig contest
发表于 2021-9-1 00:26:45 | 显示全部楼层 |阅读模式
we had a mig contest today at school between the welding class and the auto body class we used lincon 110s on 20g  and this is what i won with i dont think they look that good but it got good pen.6G zirconium 702 GTAW 2" xxheavy6G P.E.D. carbon steel GTAW 2" xxheavy3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4" 3G 316L stainless GTAW up to 1" 3G carbon steel GTAW up to 1" 3G Hastalloy GTAW up to 3/4"1G tantalum GTAW up to .060"
Reply:Nice one... What i will say, in the first picture next to the little cluster of spatter you seem to have slightly adjusted the wire angle causing that little dip, looks like you took a breath.So to sum up, stop breathing and try to keep a uniform angle and you'll be ace Metaltrades.co.uk
Reply:Thats a great looking weld for 20g. I have seen a lot worse by people who weld all the time.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Very good! weld it like you own it
Reply:Looks like more than enough weld to hold together 20gI like to play some good old rock n roll and weld to the beat.  Country dosn't seem to work for me.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthLooks like more than enough weld to hold together 20gI like to play some good old rock n roll and weld to the beat.  Country dosn't seem to work for me.
Reply:Have the body shop kids do a 7018 4G and see who winsDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:the penetration looks great. i would have probably burned thru on 20g.later,Andy
Reply:Nice job, looks like you earned it.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:ya thanks guys and the stick welding ummmthey would have no idea what to do haha but ya about the slip i was on a panel teble so i had to get cofortabl on a peice of 1 1/2" angle hahabut ya thanks guys.6G zirconium 702 GTAW 2" xxheavy6G P.E.D. carbon steel GTAW 2" xxheavy3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4" 3G 316L stainless GTAW up to 1" 3G carbon steel GTAW up to 1" 3G Hastalloy GTAW up to 3/4"1G tantalum GTAW up to .060"
Reply:It would be nice if you would type a little English.  John  SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:LOL, John, did you get alot of warp in your steel?  just curious.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by DoolittleLOL, John, did you get alot of warp in your steel?  just curious.
Reply:I'm not sure if you think im john but there was no warpage. Just a single pass on one side so there was enough heat to warp it.-Justin.6G zirconium 702 GTAW 2" xxheavy6G P.E.D. carbon steel GTAW 2" xxheavy3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4" 3G 316L stainless GTAW up to 1" 3G carbon steel GTAW up to 1" 3G Hastalloy GTAW up to 3/4"1G tantalum GTAW up to .060"
Reply:Originally Posted by welder155I'm not sure if you think im john but there was no warpage. Just a single pass on one side so there was enough heat to warp it.-Justin.
GMT+8, 2025-12-22 06:19 , Processed in 0.066449 second(s), 18 queries .
